Zmodell accessories at www.1zu220-shop.de
Hat sich bedankt: 33 Mal
Danksagung erhalten: 684 Mal
Re: Zmodell accessories at www.1zu220-shop.de
Beitrag von Alex_dn »
Set of brake disks for Märklin Siemens ER20 diesel locomotives
https://www.1zu220-shop.de/Zmodell/Zube ... 40773.html
Suitable for Märklin 81881, 88880, 88881, 88882, 88883, 88884 locomotives and train sets.
Material: Painted and brushed nickel silver 0.15 mm
Quantity: 32 pieces. It is enough to equip 4 locomotives
Set of brake disks for Märklin ICE 3 high speed train sets
https://www.1zu220-shop.de/Zmodell/Zube ... 40774.html
Suitable for Märklin 87711, 87712, 87713, 87714, 87715, 87716, 88712, 88713, 88714, 88715 train sets and cars.
Quantity: 32 pieces. It is enough to equip 4 ICE 3 passenger cars
Sets of wheel rims for Z scale trucks and buses
https://www.1zu220-shop.de/Zmodell/Zube ... 40775.html
Suitable for:
• NOCH buses
• Kibri freight vehicles kits
• Herpa Mercedes Actros trucks
• Marklin/NOCH trucks and others
Quantity: 32 pieces
"HAUPTBAHNHOF" signboard
https://www.1zu220-shop.de/Zmodell/Zube ... 40780.html
Suitable for Kibri 6700 “Bad Neuheim, Kibri 36704 “Friedrichstal”, Faller 2712 “Neustadt” and others.
Material: Photo-etched nickel silver 0.3 mm, painted in white
Quantity: 1 piece
Note: Use 0.7-0.8 mm drill bit for drilling mounting holes.
"InterCity Hotel" color signboard kit
https://www.1zu220-shop.de/Zmodell/Zube ... 40779.html
Suitable for model buildings by Luetke Modellbahn (www.luetke-modellbahn.de) and others.
Material: Photo-etched nickel silver 0.3 mm, painted in red and white
Quantity: 1 set
Special stencil for precise installation of letters comes in the package. I also recommend using an invisible non-destructive glue such as Faller Expert Lasercut glue (Art. No. 170494) here.
Additional weight inserts for Märklin GG-1 electric locomotive
https://www.1zu220-shop.de/Zmodell/Zube ... 40560.html
(This article will be available later)
Suitable for Märklin 88490, 88491, 88492
Material: Painted 5 mm stainless steel manufactured using CNC laser cutter.
Quantity: 2 pieces (1 set for 1 locomotive)
Detailed description and usage sample:
viewtopic.php?f=36&t=11999
Note about interior reproductions for driver’s cabins: these small accessories are printed on a special self-adhesive plastic film. They contains a scored line which divides horizontal and vertical parts. Please bend labels by this line before applying, so the horizontal and vertical parts can stay at 90° to each other when relaxed. I also recommend cleaning a metal part from oil and grease before applying these labels.
Driver’s cabin interior reproduction for Marklin BR 111 electric locomotives
https://www.1zu220-shop.de/Zmodell/Zube ... 40777.html
Material: scored plastic self-adhesive label
Usage sample:
viewtopic.php?f=9&t=14243
Zuletzt geändert von Alex_dn am Do 26. Nov 2020, 18:03, insgesamt 2-mal geändert.
Driver’s cabin interior reproduction for Marklin BR 120 electric locomotives
https://www.1zu220-shop.de/Zmodell/Zube ... 40778.html
Usage sample:
Driver’s cabin interior reproduction for Marklin BR 143 electric locomotives
https://www.1zu220-shop.de/Zmodell/Zube ... 40776.html
Usage sample:
Best regards,
Hat sich bedankt: 130 Mal
Danksagung erhalten: 79 Mal
Beitrag von Zoltan »
Thank you for the good and detailed instructions, Alex!
Hat sich bedankt: 499 Mal
Danksagung erhalten: 465 Mal
Alex, very fine portfolio. For everyone a good solution. ;)
Hat sich bedankt: 1070 Mal
Danksagung erhalten: 580 Mal
Really impressive. What do you think about steamer tenders? Might there be some slider contact solutions too in the future?
Hello Axel,
Yes, I have already thought about tenders. But actually there are quite many models, so I still have to figure out how many variants of sliding contacts are needed. I will know this only when I disassemble all types of tenders and make all required measurements. Everything will be done in future, but just not right now :)
Greetings,
Otti
Hat sich bedankt: 192 Mal
Danksagung erhalten: 278 Mal
Beitrag von Otti »
Alex_dn hat geschrieben: Do 26. Nov 2020, 17:52
Quantity: 1 piece
Den Schriftzug gibt es bei mir schon seit seit einigen Jahren :
https://zotti.lena-johannson.de/produkt/hauptbahnhof
Ich weiß nicht was ich davon halten soll, wenn man sich Impressionen aus dem Netz holt und das dann kopiert?!
Erinnert mich an das Desaster mit Andrej.
Ich finde das super was Alex macht, viele seiner Sachen sind absolut innovativ und professionell und ich denke das hat er nicht nötig.
Da es dieses Hauptbahnhofschild vorher an anderer Stelle nicht gab, gehe ich davon aus, das ihm meine Version gut gefallen hat.
Vielleicht sollte ich es Hommage werten.
Eigentlich gibt es so eine Art Ehrencodex bei den Zettlern möglichst nichts doppelt zu machen.
Das Ladegut gibt es aktuell noch bei Helmut und die Bremsscheiben bei Kuswa, wenn ich das richtig sehe, also was soll das?
MichaBoost
Modellbahn: LGB (1:22,5)
Hat sich bedankt: 27 Mal
Danksagung erhalten: 46 Mal
Beitrag von MichaBoost »
Hallo Otti,
das waren auch sofort meine Gedanken.
Warum in einem so kleinen Markt alles doppelt machen, zumal die am Markt
befindlichen Beladungen und Ausrüstteile von hervorragender Qualität sind.
Wäre auch nicht auf die Idee gekommen Beleuchtungen zu machen, solange
es die Platinen von Oliver Passmann gab.
Gleiches kann man auch im Bereich 3D-Druck beobachten, man traut sich ja kaum
etwas mal zu posten, schon gibt es jemand der meint er muss es sofort machen.
Ist aber wahrscheinlich der heutige Zeitgeist :evil:
Hat sich bedankt: 638 Mal
Danksagung erhalten: 1032 Mal
Hallo Otti,
sind denn die beiden Schriftzüge absolut gleich groß oder passt es zu verschieden großen Bahnhöfen?
Vor ein paar Jahren habe ich für Florian diese Schilder gebastelt, passen mit DB AG und S-Bahn Logo perfekt zu seinem kleineren Empfangsgebäude:
Da wusste ich nicht mal, dass es in Z sowas ähnliches gibt. Ich hatte es in Houten auf einer Spur 0 Anlage gesehen, dort als Bahnhof mit Bundesbahn-Keks-Schild.
Ich denke, verschieden große Gebäude und Epochen vertragen verschiedene Schilder. Zugegeben, sehe ich zwischen Alex und Deinem allerdings keinen sonderlich offensichtlichen Unterschied - allenfalls wäre es eben die Größe (Länge/Höhe)?
Otti hat geschrieben: Fr 27. Nov 2020, 00:59 Eigentlich gibt es so eine Art Ehrencodex bei den Zettlern möglichst nichts doppelt zu machen.
Wann soll das gewesen sein? Schon in den 90ern gab es zum Beispiel die Knödelpresse von Krüger und Thonfeldt. Du selber hast eine Gravita, die auch Michael gemacht hat... von wie vielen Anbietern es nun schon Kolibri und Kakadu auf Märklin 8710/8711 Basis gab, mag ich kaum mehr abschätzen.
Ich sehe da kein Problem, jeder macht es doch im Zweifelsfalle etwas anders. Bei Dir und Michael: 3D Druck vs. Ätzbleche. Bei Krüger und Thonfeldt: Guss vs. Ätzbleche. Ladegüter gab es auch früher zeitgleich von verschiedenen Anbietern, Railex, HEICO waren auch mal im Geschäft - es gab zumindest bei mir in der Ecke auf Börsen "der Kohlenmann". Ich weiß nicht, ob er seinerzeit die Einsätze auch im Versandhandel verkaufte, das war im Wesentlichen vor der Internetzeit.
Otti hat geschrieben: Fr 27. Nov 2020, 00:59 Ich weiß nicht was ich davon halten soll, wenn man sich Impressionen aus dem Netz holt und das dann kopiert?!
Da fand ich es schlimmer, weil das Modell von Andrej frech weg ohne Erlaubnis einfach abgegossen wurde und Alex damit dann Geld verdient. Andrej "verdient" Geld über die Anzahl Ausdrucke bei shapeways - bei der Abformung ist diese Anzahl = 1
Wenn zwei das gleiche auf ihre Weise nachstellen, haben zumindest beide vergleichbare Aufwendungen (in Form von Zeit oder Prototypen) gemacht.
MichaBoost hat geschrieben: Fr 27. Nov 2020, 07:08 Gleiches kann man auch im Bereich 3D-Druck beobachten, man traut sich ja kaum
Also darf SMZ nun keinen ETA150 bringen, weil NoBa gerade einen gebracht hat? Das wäre ja die Schlussfolgerung. Märklin muss seine V188 abkündigen. Dabei spielen jeweils beide in gänzlich anderen Preis- und vor allem Leistungsklassen :|
Autopiloth
Danksagung erhalten: 3 Mal
Beitrag von Autopiloth »
Ich möchte mich meinen beiden Vorpostern Otti und Micha anschließen. Trotz allem Respekt vor den sicher handwerklich gut gemachten Sachen:
Es sind oftmals (irgendwie verbesserte) Nachbauten, und wenn auch nur die Idee nachgemacht ist. Aber rechtlich nat. nicht zu beanstanden.
Was mir aber aufstößt ist dann aber dieser oft gezeigte Fotovergleich zur "Vorlage" (um sie schlecht aussehen zu lassen ?) wie im Ladegut Thread und an anderer Stelle. viewtopic.php?f=36&t=15865
Vergleiche kann man machen als Presse, Club, was auch immer an neutralem Organ oder Kunde, aber wenn ich selber als Produzent hingehe und die Produkte der Konkurrenz im Bild gleich mit "schlecht mache", so ist dies nach meinem Verständnis von Wettbewerb nicht in Ordnung. Für mich gehört so etwas gelöscht. Habe so etwas seitens eines Produzenten noch nie gesehen.
I would like to agree with both posters above: With all respect to the good work: In principle lot of this are (somehow enhanced) replicas, even if only the idea itself is cloned. Legally allowed.
But what bothers me is the fact that the manufacturer often posts pictures showing a comparison of his "new" product to the original template product (to let it look "out dated" or "poor" ?) like in the thread about cargo inlays and others. viewtopic.php?f=36&t=15865
Comparisons are no problem as long as they are made by a neutral institution, press, club, customer, whatever. But if the manufacturer himself posts pictures as a comparison showing (possible) disadvantages of other´s products this will not fit to my understanding of competition. For me such pictures have to be deleted, never saw something like that from other producers.
Thorsten
