Zmodell Ladegut für Güterwagen
Hat sich bedankt: 49 Mal
Danksagung erhalten: 933 Mal
Beitrag von Alex_dn »
Greetings to all,
I would like to introduce a new range of my Z scale model accessories – load inserts for various freight cars. Of course, this kind of accessories is already being offered by other manufacturers, but the reason why I decided to start this project was just as always – if you want to do something better, do it on your own. Some years ago, I started to use third party loads for rolling stock in my own collection. At that time, the quality offered by them was acceptable to me.
Later, I came to conclusion that everything can (and should) be made in a better way. Therefore, I decided to replace all third party load inserts in my collection with my own variants. Some load inserts used by Märklin in their own sets were also replaces with better ones. Märklin does not produce their own loads and they also use them from third-party manufacturers.
I experimented with different production technologies and materials until I was satisfied with results. Then I thought that it makes sense to offer these accessories to others too. I developed a range of different types of loads and easy numbering system. Here are some highlights of my load inserts:
1. High precision. No rework is needed at all. Each type of freight car was precisely measured, so that the load insert always ideally fits. It is not loose – there are no gaps between the walls and the edge of the load. And it is not tight – the load can be easily removed from the freight car whenever you wish without any additional efforts.
There is a small exclusion from the rule. Sometimes, old freight cars become slightly bent or crumpled. It is caused by the aging of the plastic, which, in turn, may be a result of the constant storing of the model at a direct sunlight. In this case, installing and removal of the load insert may be a bit more complex than usual.
Based on my experience, it is not a big problem, as the aging issue is true mostly to the very old models that were produced around 20 years ago and more.
2. Compatibility with packaging material. Most types of my load inserts ensure full compatibility with packaging boxes – any freight car can be easily put into the box without removal of the load insert. Bulk loads do not have excessive “hills” that protrude outside the top of the freight car too much.
There are few exceptions though – for example, for some types of loads with wood or pipes. Most other types of load inserts (all bulk materials) ensure full compatibility with packaging.
3. Plastic base. I don’t use plywood as a base of my load inserts. Polystyrene offers higher precision and overall better technological look for the final product. I use polystyrene sheets with different thickness, according to the requirements of a particular type of freight car. Sometimes desired thickness of the base is achieved by combining multiple sheets.
All parts are milled out on a high precision CNC milling machine.
4. Perfect height of the load. All types of my load inserts are ideally adjusted by height. When I used loads from other manufacturers for my own collection in the past, I often had to adjust the height of the load, because it always turned out than it is either too low or too high.
5. Different colors of base material. I use different colors for base material. For dark bulk loads such as coal, ore and others, I use black polystyrene base. For light types – sand, sawdust, limestone, I use white polystyrene. In some cases, gray polystyrene used along with white and black. It helps to leave the base completely invisible even at the very edges of the load insert.
6. Natural materials. No cast resin imitation or something like this. Only natural materials used for all types of loads, including all bulk and wooden materials – natural coal, ore, fine-grade sand and gravel, as well as very fine sawdust, metal shavings and other.
7. Superb stabilization of bulk loads. All bulk loads are very reliably stabilized with a special adhesive liquid that prevents crumbling. After solidifying, this liquid does not change the look of the bulk load and remains invisible. This is true even to such a delicate material as a sawdust.
Note: Of course, if you try to scratch the bulk load intentionally – you will surely do it. Stabilization works perfectly for “normal” usage scenario.
8. Metal base. Some load inserts require a very thin base material. It relates mostly to the loads for flatcars. Thin plastic base cannot be strong enough, so I decided to use metal for the base in this case. All my load inserts for flatcars use 0.3 mm photo-etched metal as a base.
9. Comprehensive usage information. Each load insert comes with a complete list of train sets and single models where it can be used. Information about base thickness and precise weight is also supplied. Each load insert has a plastic label on the bottom side with a product code and short description.
Now about numbering system and types of loads. I developed a list of most popular kinds of loads. Some specific types may be added later:
001 – Coal
002 – Ore
003 – Gray Gravel
004 – Brown Gravel
005 – Sand
006 – Wood
007 – Metal scrap
008 – Sawdust
009 – Metal Shavings
010 – Limestone
011 – Glass
012 – Beet
013 – Stacked Lumber
014 – Pipes
015 – Wire Coils
016 – Steel Coils
017 – Sheet Metal
018 – Metal Beams
Not all types of loads are suitable for all types of freight cars. Some loads are specific only to the particular types of freight cars. For example, you will never see a wood load for OOtz 50, OOtz 43 or EAMOS dump cars.
Manufacturers:
MRK – Märklin (Germany)
FR – Freudenreich (Germany)
AZL – AZL (USA)
MTL – MTL (USA)
ROK – Rokuhan (Japan)
TEN – Tenshodo (Japan)
PRL – Prmloco (Japan)
Here is a sample – ZM-MRK-EANOS-001. “ZM” stands for “Zmodell”, MRK is “Märklin”, EANOS is a type of the suitable freight car, and “001” is a code of the type of load, which is coal in this sample.
Now the most important: all my load inserts are available for sale at www.1zu220-shop.de in a dedicated subsection:
https://www.1zu220-shop.de/Zmodell/Lade ... 00246.html
You will get all advantages of domestic shopping – no international bank transfers with additional fees, no long shipping times, no import tax, just a usual payment and fast and reliable shipping within EU. Most of load inserts are already in stock there. Some other types will be added later.
Now let me show you some pictures. Here is a set of different load inserts for Märklin type EANOS freight car. The base is made of two 3mm thick polystyrene parts joined together. Lower part have grooves for hatches that hold a metal floor inside the car:
And here is a small comparison of similar load inserts from different manufacturers. Here you can see a sawdust (or wooden chips) loads from the following manufacturers – Spur Z Ladegut, Duha, Heico and the last one – from me. Märklin uses Duha and Heico loads in some models. I don’t want to convince anybody about which one is better – let everyone decide on their own:
This is one more comparison of gray gravel load inserts for MTL 50’ Gondola. Original load from MTL (above) is a slightly weathered piece of cast resin. The center one is from Spur Z Ladegut. Lower one is mine:
Upper one is mine, lower one is from MTL:
Now about gaps. Left one is from MTL, right one is mine:
Comparison of two limestone loads (I applied square pieces of foamed material to the load insert from Spur Z Ladegut on my own when I used it in my train sets):
Comparison of two wood loads inserts for Märklin type EANOS freight car. Left one is from Spur Z Ladegut, right one is mine:
Now let’s come across current assortment:
Märklin EANOS – Coal
https://www.1zu220-shop.de/Zmodell/Lade ... 40712.html
Märklin EANOS – Ore
https://www.1zu220-shop.de/Zmodell/Lade ... 40713.html
Märklin EANOS – Gray Gravel
https://www.1zu220-shop.de/Zmodell/Lade ... 40714.html
Märklin EANOS – Brown Gravel
https://www.1zu220-shop.de/Zmodell/Lade ... 40715.html
Märklin EANOS – Sand
https://www.1zu220-shop.de/Zmodell/Lade ... 40716.html
Märklin EANOS – Wood. Thin etched metal holding straps painted in gray were used in this type of load:
https://www.1zu220-shop.de/Zmodell/Lade ... 40717.html
Märklin EANOS – Sawdust
https://www.1zu220-shop.de/Zmodell/Lade ... 40718.html
Type EANOS freight cars from Freudenreich have slightly different internal dimensions, so I decided to produce separate articles for these cars:
Freudenreich EANOS – Coal
https://www.1zu220-shop.de/Zmodell/Lade ... 40719.html
Freudenreich EANOS – Ore
https://www.1zu220-shop.de/Zmodell/Lade ... 40720.html
Freudenreich EANOS – Gray Gravel
https://www.1zu220-shop.de/Zmodell/Lade ... 40721.html
Freudenreich EANOS – Brown Gravel
https://www.1zu220-shop.de/Zmodell/Lade ... 40722.html
Freudenreich EANOS – Sand
https://www.1zu220-shop.de/Zmodell/Lade ... 40723.html
Freudenreich EANOS – Wood
(This article will be available at www.1zu220-shop.de later)
Freudenreich EANOS – Sawdust
https://www.1zu220-shop.de/Zmodell/Lade ... 40724.html
Märklin EAOS – Coal
https://www.1zu220-shop.de/Zmodell/Lade ... 40725.html
Märklin EAOS – Ore
https://www.1zu220-shop.de/Zmodell/Lade ... 40726.html
Zuletzt geändert von Alex_dn am Do 26. Nov 2020, 16:36, insgesamt 1-mal geändert.
Re: Zmodell Ladegut für Güterwagen
Märklin EAOS – Gray Gravel
https://www.1zu220-shop.de/Zmodell/Lade ... 40727.html
Märklin EAOS – Brown Gravel
https://www.1zu220-shop.de/Zmodell/Lade ... 40728.html
Märklin EAOS – Sand
https://www.1zu220-shop.de/Zmodell/Lade ... 40729.html
Märklin EAOS – Wood. Thin etched metal holding straps painted in gray were used in this type of load:
https://www.1zu220-shop.de/Zmodell/Lade ... 40730.html
Märklin EAOS – Sawdust
https://www.1zu220-shop.de/Zmodell/Lade ... 40731.html
Märklin EAOS Track Cleaning Car – Coal
https://www.1zu220-shop.de/Zmodell/Lade ... 40732.html
Märklin EAOS Track Cleaning Car – Ore
https://www.1zu220-shop.de/Zmodell/Lade ... 40733.html
Märklin EAOS Track Cleaning Car – Gray Gravel
https://www.1zu220-shop.de/Zmodell/Lade ... 40734.html
Märklin EAOS Track Cleaning Car – Brown Gravel
https://www.1zu220-shop.de/Zmodell/Lade ... 40735.html
Märklin EAMOS – Coal
https://www.1zu220-shop.de/Zmodell/Lade ... 40736.html
Märklin EAMOS – Ore
https://www.1zu220-shop.de/Zmodell/Lade ... 40565.html
Märklin EAMOS – Gray Gravel
https://www.1zu220-shop.de/Zmodell/Lade ... 40737.html
Märklin EAMOS – Brown Gravel
https://www.1zu220-shop.de/Zmodell/Lade ... 40738.html
Märklin EAMOS – Sand
https://www.1zu220-shop.de/Zmodell/Lade ... 40739.html
Märklin EAMOS – Sawdust
https://www.1zu220-shop.de/Zmodell/Lade ... 40740.html
Märklin EAMOS – Limestone
https://www.1zu220-shop.de/Zmodell/Lade ... 40741.html
Now I would like to add some comments about load insert for Falns/OOtz 50 “Erz III” freight wagon. Making a proper load insert for this type of freight car was a bit more complex task due to its specific construction.
Märklin produces some OOtz 50 wagons with pre-installed load inserts, but they are being installed during assembly at the factory, before the car were assembled completely. And such pre-installed loads for this type of car are not removable. I refused to do it in the same way, as I assume that not everyone will dare to disassemble the car just to install a load insert in it. I chose easier, but the same effective solution. It is better to explain it in pictures. No need to disassemble the car to install a load; I just disassembled one car in order to show how it works:
The base of the load for Erz III car has a special shape that allows to fit inside ideally. The load does not shakes or swings from one end to another, it is fixed in place very stably. And what is important – like all my other bulk load inserts, it does not protrude outside the top of the car, so it can be safely put into the packaging box. So, here is it:
Märklin Falns/OOtz 50 – Coal
https://www.1zu220-shop.de/Zmodell/Lade ... 40749.html
Märklin Falns/OOtz 50 – Ore
https://www.1zu220-shop.de/Zmodell/Lade ... 40750.html
Märklin Falns/OOtz 50 – Gray Gravel
https://www.1zu220-shop.de/Zmodell/Lade ... 40751.html
Märklin Falns/OOtz 50 – Brown Gravel
https://www.1zu220-shop.de/Zmodell/Lade ... 40752.html
Märklin Falns/OOtz 50 – Sand
https://www.1zu220-shop.de/Zmodell/Lade ... 40753.html
Märklin Falns/OOtz 50 – Limestone
https://www.1zu220-shop.de/Zmodell/Lade ... 40754.html
The story with OOtz/OOtu “Erz II” freight car is almost the same. Thanks to a special shape of the base, bulk load does not have a high “hill” and does not protrude from above:
Märklin OOtz 43/OOtu – Coal
https://www.1zu220-shop.de/Zmodell/Lade ... 40755.html
Märklin OOtz 43/OOtu – Ore
https://www.1zu220-shop.de/Zmodell/Lade ... 40756.html
Although Erz II cars were used mostly for transporting coal and ore, I added two more variants – gray and brown gravel for those who want diversity:
Märklin OOtz 43/OOtu – Gray Gravel
https://www.1zu220-shop.de/Zmodell/Lade ... 40757.html
Märklin OOtz 43/OOtu – Brown Gravel
https://www.1zu220-shop.de/Zmodell/Lade ... 40758.html
And other types of loads for other freight cars:
Märklin E 037 – Coal
https://www.1zu220-shop.de/Zmodell/Lade ... 40742.html
Märklin E 037 – Ore
https://www.1zu220-shop.de/Zmodell/Lade ... 40743.html
Märklin E 037 – Gray Gravel
https://www.1zu220-shop.de/Zmodell/Lade ... 40744.html
Märklin E 037 – Brown Gravel
https://www.1zu220-shop.de/Zmodell/Lade ... 40745.html
Märklin E 037 – Sand
https://www.1zu220-shop.de/Zmodell/Lade ... 40746.html
Märklin E 037 – Sawdust
https://www.1zu220-shop.de/Zmodell/Lade ... 40747.html
Märklin E 037 – Limestone
https://www.1zu220-shop.de/Zmodell/Lade ... 40748.html
And here is one of the most interesting load inserts in my assortment – bulk load for type RES flatcar. The base of this load insert is made of 0.3 mm etched metal. Märklin produces two types of RES flatcars – with flat (for example 82423, 82424) and ribbed sides (for example 81071, 82425). This load insert is suitable for both types:
Märklin RES – Gray Gravel
https://www.1zu220-shop.de/Zmodell/Lade ... 40759.html
Märklin RES – Brown Gravel
https://www.1zu220-shop.de/Zmodell/Lade ... 40760.html
Märklin RES – Sand
https://www.1zu220-shop.de/Zmodell/Lade ... 40761.html
One more load insert with 0.3 mm metal base is for Klms 440 flatcar – old but very popular model from Märklin:
Märklin Klms 440 – Coal
https://www.1zu220-shop.de/Zmodell/Lade ... 40762.html
Märklin Klms 440 – Gray Gravel
https://www.1zu220-shop.de/Zmodell/Lade ... 40763.html
Märklin Klms 440 – Brown Gravel
https://www.1zu220-shop.de/Zmodell/Lade ... 40764.html
Märklin Klms 440 – Sand
https://www.1zu220-shop.de/Zmodell/Lade ... 40765.html
MTL 50’ Gondolas should not run empty as well (these articles will be available at www.1zu220-shop.de later):
MTL 50’ Gondola – Coal
MTL 50’ Gondola – Ore
MTL 50’ Gondola – Gray Gravel
MTL 50’ Gondola – Brown Gravel
MTL 50’ Gondola – Metal Scrap
MTL 50’ Gondola – Limestone
A big number of load inserts for many other types of freight cars is also in development now and will be added to the product range in the nearest time.
Best regards,
Wenn ich die Preise sehe, was das Ladegut für einen Wagen kostet, finde ich den Preis für dieses Konvolut gar nicht mal so teuer :roll: https://www.ebay.de/itm/Railex-Spur-Z-1 ... SwKk9fTM-T
meint FJ
Hat sich bedankt: 2287 Mal
Danksagung erhalten: 736 Mal
das Döschen ist ja mittlerweile wirklich ein Sammlerstück...
cozi hat geschrieben: Do 26. Nov 2020, 17:32 das Döschen ist ja mittlerweile wirklich ein Sammlerstück...
....und hat einst nur 35 DM gekostet ;) und war das erste Z-Ladegut auf dem Markt.
Zuletzt geändert von f-j.huwig am Do 26. Nov 2020, 17:44, insgesamt 1-mal geändert.
...was nicht wenig Geld war - im Vergleich zu den Lokomotivchen und Wägelchen... :d+w:
Zmodell accessories at www.1zu220-shop.de
Hi friends,
I would like to let everyone know that a number of my Z scale accessories is available for purchase at www.1zu220-shop.de. Some of them were already available there before, but after a number of requests, I decided to add more items to my section on the website and to describe them together in this topic.
Along with my load inserts, most of these articles are in stock at the moment. Surely, you will get all obvious advantages of domestic shopping – no complex international bank transfers with additional fees, no long shipping times, no import tax, just a usual payment and fast and reliable shipping within EU.
First of all, I added all types of brass sliding contacts that I developed so far. Important note: even after a good cleaning, brass may show some oxidizing with time. I recommend cleaning brass sliding contacts in phosphoric acid before installation.
Phosphoric acid is relatively safe chemical (in comparison with other substances); it is widely used for rust removal, as well as a flux for soldering iron and aluminum, and even in a dental medicine. It can be purchased, for example, here:
https://www.ebay.de/itm/Phosphorsaure-7 ... 4267880953
After deoxidizing in phosphoric acid, brass parts should be cleaned in IPA (Isopropyl Alcohol) and dried completely.
Important: All operations should be performed will all safety precautions, including wearing protective gloves and eyeglasses!
All sliding contacts come flat. You should bend them on your own. I enclosed detailed instructions on how to do this. Small precise tweezers can be used for this. There are also special bending devices that can be found in modelling shops. Please note that in most cases, if sliding contacts will be bent incorrectly, they may not work.
Sliding contacts for Märklin IV-VI Era 4-axle passenger and baggage cars
https://www.1zu220-shop.de/Zmodell/Zube ... 40767.html
Suitable for most types of modern IV-VI Era 4-axle Märklin passenger and baggage cars, rebuilt passenger cars (Umbauwagen), and also for Schürzenwagen (except Schürzenwagen restaurant car).
Material: High-flexible brass 0.05 mm
Quantity: 2 pieces (1 set for 1 passenger car)
Usage samples:
viewtopic.php?f=16&t=14185
viewtopic.php?f=16&t=14609
Attention: Installation of this product requires drilling and soldering. Please follow the installation instructions on the package.
Sliding contacts for Märklin Henschel-Wegmann 4-axle passenger cars
https://www.1zu220-shop.de/Zmodell/Zube ... 40766.html
Suitable for Märklin 81436 “Henschel-Wegmann Train” and 81176 “Blauer Enzian” train sets.
Usage sample:
viewtopic.php?f=16&t=15850
Sliding contacts for Märklin 3-axle Donnerbüchse passenger cars and Prussian passenger and baggage cars
https://www.1zu220-shop.de/Zmodell/Zube ... 40768.html
Suitable for Märklin 8104, 8703, 8704, 8705, 8706, 8707, 8708, 8776, 81191, 87055, 87060, 87040, 87041, 87071, 87073, 87506 train sets.
Usage sample:
viewtopic.php?f=16&t=14651
Attention: Installation of this product requires soldering. Please follow the installation instructions on the package.
Sliding contacts for Märklin 2-axle Donnerbüchse passenger cars
https://www.1zu220-shop.de/Zmodell/Zube ... 40769.html
Suitable for Märklin 8750, 8751, 8776, 81416, 81417, 81871, 81770, 87505, 87507, 87508, 87509, 98104 train sets.
Usage sample:
Sliding contacts for Märklin 2-axle Donnerbüchse baggage car
https://www.1zu220-shop.de/Zmodell/Zube ... 40770.html
Suitable for Märklin 8752, 81871, 87505, 87507, 87508, 87509 train sets.
Usage sample:
viewtopic.php?f=16&t=15309
Sliding contacts for Märklin 2-axle Württemberg passenger cars
https://www.1zu220-shop.de/Zmodell/Zube ... 40771.html
Suitable for Märklin 8103, 8700, 8701, 8739, 81390, 81420, 81563, 82101, 87001, 87009, 98031 train sets.
Usage sample:
viewtopic.php?p=187923
Now all about wheelsets. First of all, one important note: I recommend using a non-destructive glue for attaching any type of brake disks or wheel rims, such as Faller Expert Lasercut glue (Art. No. 170494) for example. Using polystyrene or cyanoacrylate glues is not recommended, as they can damage painted areas on brake disks.
Sets of brake disks for Märklin TRAXX locomotives and compatibles
https://www.1zu220-shop.de/Zmodell/Zube ... 40772.html
Suitable for Märklin 81481, 81800, 88231, 88232, 88370, 88371, 88481, 88482, 88483, 88484, 88520, 88521, 88522, 88523, 88524, 88191, 88192, 88193, 88194, 88195 train sets and locomotives.
Material: Painted and brushed nickel silver 0.15 mm
Quantity: 32 pieces. It is enough to equip 4 locomotives
Zuletzt geändert von Alex_dn am Do 26. Nov 2020, 17:58, insgesamt 2-mal geändert.
Mark
Hat sich bedankt: 20 Mal
Danksagung erhalten: 5 Mal
Beitrag von Mark »
Wow - really nice work! Thanks for this great addition to the Z-World :)
